wall accessories parameters
Cosminn
Hello everyone, i want to create one object, type "wall accessories", but i need to know all the parameters of the wall. from where can i find? for example, if i want to use the real length of the wall (even if there are embedded columns)
Can i?, or the core thickness, etc. Thanks in advance.
Sincerely,
Daniel
Frank Beister
You have to set the correct subtype. Then you get blue parameters, which are filled, when object is associated with a wall.
Cosminn
Thank you
Sincerely,
Daniel
