Learn more
adamsb
window parameters in AC19
With the new forced hierarchy of window settings in AC19, I can't seem to find out where the setting is to choose the number of unit shown in a multi unit window.
In AC18, this selection seemed to only exist in the "All Parameters" option of the custom settings. This was a little hidden before, but at least existed.
Does anyone know how to get to it now? Thanks so much!
AC21 64-bit
Mac OSX 10.12, 4.2 GHz Intel Core i7, 64 GB mem
Mac OSX 10.11, 3.4 GHz Intel Core i7, 32 GB mem
13 Replies 13
What is the exact name of the object?
The Horizontal Multi-Sash Window 19 has it both on the Shape and the Window Settings and Opening pages, so I guess you might be using a US-specific Window.
(You should update your signature t reflect that you are now on AC19.)
adamsb
Thanks for the heads up on the signature!
Also, the window that brought this to light for me is the W Awning 1 MU 19. However, I also don't see a unit selection option for the W Fixed MU 19 window either.
Thanks!
AC21 64-bit
Sorry, I am using the INT version so I don't have this Window.
Maybe someone with the US version can chime in.
adamsb
No worries, hopefully someone else can help!
Curious then, what do you INT guys use for MU (multi-unit) fixed windows?
AC21 64-bit
There is a Window called "Horizontal Multi-Sash Window 19", where you can specify the pane number, and also it has a "Multiply Units" checkbox, which you can check and then specify the number of units.
There is also a "Vertical Multi-Sash Window 19", which works the same way, only in the vertical direction.
adamsb
Interesting! On those windows, which settings panel has the option for the number of units? (wall opening, connecting structures, etc.)
AC21 64-bit
The Window Settings and Opening page of the object.
See attached image.
adamsb
Ah, interesting again! Thanks Lazlo, that helps to know, but no option like that exists on my Window Settings and Opening page.
Is there a way to make sure that this option gets added to these objects on an upcoming Update?
AC21 64-bit
The best would be for you to make a wish for either these options to get added or for the Window object to be included in the US library as well.
Or, you could download the INT version from myarchicad.com, extract its Library Container File and use the objects from there.
