window - showing dimension marker - interactive schedule
Need to setup window & door schedule on an existing project. I need to switch the dimension marker on. Although I can adjust all the marker settings, the marker does not show on the drawing - The only way to get some info onto the drawing seems to be with a locked (uneditible) text marker under listing and labeling - which also is not adjustable in a linked mode - (updating info on an existing window) How now?
Djordje
Display options, Doors and windows, Show with dim
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
So simple, Thanx!
