We value your input!
Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
3d text
in archicad 10 ver, it is unable tilt/rotate the 3d text object in vertical direction. any help
thanku
pradeep
9 REPLIES 9
thanku
pradeep
Is this what you want to do?
The setting is highlighted here
Rod Jurich
pradeep
This may assist also.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
perso.orange.fr/archilib.od/ also has some 3d text objects which may be of use.
Rod Jurich
pradeep, on further investigation the following part will allow you to rotate in either 'X', 'Y' or 'Z' axis.
More speed, less haste next time (for me that is )
Rod Jurich
Rod wrote:
pradeep, on further invetigation the following part will allow you to rotate in either 'X', 'Y' or 'Z' axis.
thanku,
i sloved my problem with ur gsm object.
text has to be rotated on y,z axis not only on x axis
ok thanku for ur object which are in that website.
i download the waterfountain.gsm , when i used it & did animation it not showing an 3d animation in it(live object).
Djordje
Pradeep,
When you do the animation, check "rebuild for each frame"
Also, please do not use abbreviations (u instead of you, ur instead of your). This is not an SMS forum.
Thanks,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
