Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
AC9 Network license Installation
Hi all,
I had a problem on installing ArchiCAD9 network license version.
The procedure i had followed is:
1.Installing the software in all the machines.
2.Installing network license Cd in all the machines.
3.Inserting wibu key in server machine.
4.lanching network serve from start menu>programs>wibu
key>network serve.
After completing all these steps when i lanch AC9 it was giving a warning box, WIBU KEY WAS NOT FOUND (128) RUN IN DEMO MODE OR QUIT.
Even i have tried from control panel> network>Server ip address, there i can see the key number when i click test option.
can i know what r the extra precautions should i take.
Regards,
Rajesh.
1 REPLY 1
Ben Odonnell
HI there,
I have posted an answer for you in this http://archicad-talk.graphisoft.com/viewtopic.php?t=6016&highlight= thread.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
