2006-12-04
01:35 AM
2024-07-09
11:11 AM
Aruzhan Ilaikova
2006-12-04 08:54 AM
2006-12-05 02:01 AM
2007-01-31 04:31 PM
2008-01-21 09:04 PM
alexwhite06 wrote:Hi I am quiet new with ArchiCad. We are trying to run ArchiCad 10 or 11 on a
We have a terminal server at work which has Archicad 10 installed on it, which we have setup so employees out of the office can user our licenses of Archicad, instead of giving them all USB key licenses. Sometimes when our users do not log out of a terminal session properly, or even for other unknown reasons, the terminal server says that this user is running more then one application of Archicad. Now this would not be a problem if our WIBU key didn't assign licenses to each copy that is for some reason open. I was under the impression that any user could have as many copies of Archicad open as they wanted with it only taking on license.
We are all running Archicad 1010 with Wibu key version 5.0, and Windows server 2003. Thank you for any help.
2008-01-21 11:00 PM
alexwhite06 wrote:Hi. I'm afraid this is not going to be much help, but we are experiencing a similar problem in our office with a 20 keyserver licence. We frequently run out of licences only to find that a few users have been allocated two licences.
...Sometimes when our users do not log out of a terminal session properly, or even for other unknown reasons, the terminal server says that this user is running more then one application of Archicad. Now this would not be a problem if our WIBU key didn't assign licenses to each copy that is for some reason open. I was under the impression that any user could have as many copies of Archicad open as they wanted with it only taking on license.
2008-01-22 01:50 AM
KenMcN wrote:I'm not sure of the exact settings because I don't have access to the right machine at the moment.
