Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
SOLVED!
Connection to the server could not be established
RobPatt75
I am trying to upload my software license to the pool and it wont connect to the server and complete it.
I am doing this from ArchiCAD 24 and only did this late last week successfully.
I am signed into the License pool and it is not appearing as available to download to my other new computer which has AC 27 installed.
I had done this last week as well.
urgent assistance required please
1 ACCEPTED SOLUTION
Solution
Karol Sochacki
Hi Rob,
I had the same problem, updating LM helped.
I found a useful link with a more detailed explanation and downloadable update.
I hope this will help.
https://community.graphisoft.com/t5/Installation-update/Security-Update-for-Archicad-22-25-and-Licen...
7 REPLIES 7
Solution
Karol Sochacki
Hi Rob,
Immediately after I typed this out and sent it I spotted the large bit of text at the top of the screen mentioning that as of the 6th of that month which was the day before, Graphisoft had done an update to the licensing software for versions 22 -25 so of course I did that and it worked immediately. Problem solved. Thanks for your reply though. Same solution which would have been spot on. Cheers
kiwichick
I have had this same issue this morning "connection to the server could not be established"
I have a paid perpetual archicad 26 licence, how do i fix this?
Have you installed the security update mentioned in previous posts?
Juanesbg11
I have the same problem "connection to the server could not be established". I use a perpetual license for archicad 26, also didn't install the security update because it's supposed to be for Archicad 22-25, so i'm not really sure how to fix it, should i install the update or does anyone have any solution? Thanks
Oleksandra Vakariuk
Hi all,
The License Manager Tool has to be updated regardless of the Archicad version, please install the update to resolve the issue. We have updated the article and Graphisoft Insights post accordingly.
Sorry for the inconvenience.
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer
Thanks a lot, that helped!
BUT please: I updated the Archicad which doesn't work anymore with my key, no usable error message, no warning.
Somehow I realise that I need to update the key as well. But the program which updates the key doesn't work... no usable error message...
So I finally end up in a forum (thanks again!) so I can realise that I need to update the Licence manager so I can update the key.
I hope my Archicad will work after restarting - it is nor working now and the update finished without any message...
Update: I missed the message that I need to Update the CodeMeter driver as well. 😕 So finally I tried it, but I still have the error message from
Licence Manager, anyway I just pressed 'Cancel' (logical choice isn't it?) and I updated the licence... Fingers crossed.
Could it be any more complicated? Maybe another key which we use to make the Licence Manager work?
Setup info provided by author
