Have a problem with Archicad 24 on my macOS
I installed archicad about 11-12 of Jan and used it as well. After It I had a problem, smth like "problem with license file". Then I deleted ALL of parts Archicad. After installed Archicad 24 again from website.
Set my account and started, but after I tried to launch my last project I have problem:
"This Trial-version file can be opened only on the computer on which it was saved"
It is the same computer, IDK how to fix it, help pls:
3 Replies 3
Eduardo Rolon
That is how the Trial version works.
If you start a project in Trial mode and you either try to open in another computer, the trial ends or you uninstall AC without buying a license then the file becomes unusable.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Omg... But it is the same computer, why developers say "On the same computer", not like "The same trial version file on the same computer"... So, isnt possible to open my file? Because I still have about 11 days of trial (same trial)
Eduardo Rolon
If that is what the instructions say then I agree that they are not very clear.
AC29 US/INT -> AC08
