2025-04-07 11:23 AM
Hello!
I'm trying to open an older version of a project that has been developed in archicad 25, and i'm running into a lot of problems connecting to the license i have ( collaborative license for our). There are a lot of modules that need update if i want to open in it in Archicad 28 so i wouyld rather save time and open it in 25.
I tried everything i found on the forum and managed to get from: archicad 25 not connecting to the internet to now telling me after i logged in that i don't have a license. Please help!
Is archicad 25 not available anymore for my license?
Thanks
Solved! Go to Solution.
2025-04-07 11:34 AM
If you have a collaboration license, I believe that will only work back to version 26.
You need a separate cloud license to open 25.
You might need to speak to your local distributor to obtain that license.
2025-04-07 11:34 AM
2025-04-07 03:46 PM
Ok, i understand. It must be something recently changed in the updates of license manager etc.. Cause i remember a few months ago i could work in archicad 24 without any problem. Now it's not working in 24 also.
Thank you! I will stick with updating the projects to 28 then.
2025-04-08 03:02 AM
If you already owned a perpetual license for Archicad and then just recently switched that license to a collaboration subscription, then you should still be able to open your old version files, because you should have an old perpetual license.
If you just purchased a new collaboration subscription, then that will work only for 26+.
I am not sure if/how a new collaboration subscriber can access older files other than contacting their local distributor.
2025-04-08 04:15 AM
If you did have an old perpetual licence, check to see if you still have it assigned to your user.
Ling.
