Walls cut at an angle
I am putting a slanted roof on my building and I need to cut the tops of the walls at an angle so that they meet up with the roof nicely.
Does anyone know how to do this?
Thank you
-Jonelle
1 Reply 1
Generally, use a Solid Element Operation (boolean) to subtract the wall(s) from the roof(s) with upwards extrusion. The trimming is then dynamic.
For static trimming, thee is the Trim to Roof command.
See the user guide for example of each.
