Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
disappearing walls - pls help!
Hi all, really hoping someone can help me here. I'm using the student version of archicad 10 and I will be working on my plan as usual and then all of a sudden my walls will just disappear. They are still there and I can select them and modify them, but I just can't see them. Does anyone know why this is happening? Possibly need to update my graphics card or drivers or something???
Any help is much appreciated!!!
10 REPLIES 10
There are many possible reasons for this. You'll have to give us more information. Some guesses:
-The wall color is the same as the background
-The wall elevation places it above the current cut plane or story
Eric, I don't think it would be either of those reasons for the fact that the problem happens mostly after going into 3d view and then closing it again. The walls can be seen beforehand and then afterwards they have disappeared, even when I have changed nothing. Also, it has happened to quite a few other people in my class and they say also that it seems to happen mainly after opening and closing 3d view.
Djordje
It looks like you are not alone, Kelly, and that it is happening only down under
http://archicad-talk.graphisoft.com/viewtopic.php?t=11880
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Okay, my teacher for our cad class at uni has just posted to us a bit of a 'quick fix' for the problem. Hopefully this will help everyone for the time being until there is a proper solution...
It appears that there is a problem with the actual default "pen set combination" in the student version of ArchiCAD on the pc. Now that i have seen the issue in front of my own eyes, i will now again chase Graphisoft with a detailed explanation of the issue, and see if they can resolve the problem properly.
In the meantime, here are the steps you can follow so that you do not have to relaunch ArchiCAD everytime this problem.
When the lines turn white on you in ArchiCAD student version.
1. Go up to the "Options" menu and select "Element Attributes" and the "Pens & Colours (Model View)". This is where you can presetup combinations of pen colours and weights (like AutoCAD etc.)
2. The pen sets on you project are most likely set to the first one "Australian Black Pens 1" or something similar to that.
3. Change the pen set to something else, for example "Australian Colour". Then click ok.
What appears to be happening is that any pen that is set to a black colour tries to reset itself as a white pen. So when you change the pen table from black colours to anything else (such as grey or pink or anything colour) then the pen appears again. The pen set combination is another part that can be set up before creating a "view set" so if you do click on a view set that has been created, the pen set will revert back to the original one, and your lines will most likely turn to white.
I know this is not a proper fix, because if you change the pen set back to the original settings, they go white again. But at least this allows you to keep working without having to restart ArchiCAD every time it happens.
Any other progress? Any other solutions besides the "quick fix"? We want to use black pens!
Paul Lucke
Sorry, no more progress on the problem as yet. I feel your pain though, so very frustrating!!!
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
does the problem occur when updating the EDU version to Build 1010?
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
ahhh I'm going to look stupid, but what is Build 1010???
__archiben
it's the latest patch/bug fix for the program....
Help>Check For Updates...
should launch your web browser and send you to GS's update page. follow the instructions and download as neccessary.
~/archiben
b e n f r o s t
