3 point arch and soldier course
Hi! how I can create an Arch like this in ease way ?
Thank you
4 REPLIES 4
Erich
That depends on what you think is easy.
Using the simple tools we all have would be to make a custom door that consists of the wallhole slab in the shape of the opening and the surrounding brick work. This will work fine, but each different variation will need to be made separately.
I think that ArchiCAD has an elliptical arched door in the stock library. You could use that and then add the brick work separately.
Alternatively, this can be scripted so you can use a single object for multiple cases. Obviously this takes more skill to accomplish.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Th it was helpful
You could also look at making the soldier course shape as a profile, creating a wall or beam with that profile that extends across target wall and then using SEO to subtract with downward extrusion.
Thanks I already fixed.
Thanks
