3-way wall junction confusion
heathldesign
hi there, I have read about wall junction priority but i can't seem to get the correct result. The walls without fill are the same materials. how do i get the thin wall to join correctly with the bigger composite. i know if i move the reference line of the thick wall, then create an offset it will clean up, but snapping things like slabs becomes potentially problematic.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.1. AC 27, 6000 USA
Lingwisyer
Guru
Junction clean up will only occur when the reference lines of the related objects intersect with each other.
Setting an offset to your wall should work fine as your concern with snapping is needless as you can snap to each active dividing line within a composite.
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
Lingwisyer
Guru
Ling.
heathldesign
Thanks Ling. I guess i knew that.
Heath
