2005-01-04 01:24 AM
2005-01-04 11:15 PM
Dan wrote:Ok Dan, but you have to tell us how you are doing the ones on your web site.
...tell us how you are achieving your nicely trimmed out rakes and eave overhangs.
thanks,
Dan K
2005-01-04 11:19 PM
2005-01-04 11:41 PM
2005-01-05 03:14 PM
Jay wrote:Jay,
Dan, Is this an object that you created. Again it sounds like it is for use towards the end of Design.
Steve wrote:Steve,Dan wrote:Ok Dan, but you have to tell us how you are doing the ones on your web site.
thanks,
Dan K
2005-01-06 09:09 AM
Dan wrote:If I had "smart" objects I might use them for making models for rendering only but not for getting better sections or 2D stuff into my CD's. A smart part that is complex enough to generate a good detail is not something I have seen yet. When it comes to sections, I just model enough to show the limits of what I need to see and use a patch from my library or cannibalize some details from another project to paste into it. Attached is an example of the details I make with patches on a crude section. These are is also where I get the lines to use with the profiler tool and make parts for the model to be rendered. ( I use two models for some projects, the main one for generating the working drawings and the other I use for rendering only)
... Over the past few years I've changed my focus to more Production Residential work and have found that I need "smart" objects to make the process more efficient....
2005-01-06 03:56 PM
2005-01-06 05:55 PM
2005-01-09 09:37 AM
Jay wrote:I finally got sick of AC not modelling cladding that I created a 'window like' object that slices grooves out of the surface (horizontal or vertical or both) at various spacings. This is one application. Just make the wall the extra thickness fo rhte battens. Also has the advantage of moving with the wall and being cut by windows automatically.
What is the best way to produce an material that can display in 3D (Internal & OpenGL) a realistic board & batten siding.
2005-01-09 06:54 PM
Susanka would love to work with your you house plans.Nah....There's no "away" room....
2005-01-09 07:10 PM
HANIEL wrote:I thought about that approach, too - but just using solid element subtract, since that does the same thing as your object I assume?
