2022-03-07 08:57 AM
Help, I am working on an Archicad file that was previously worked on by someone else, when I view items in 3d, the 3d object itself does not align with its hotspots. See attached.
AC24 | Windows 10 Pro | Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz 3.40 GHz | 16.0 GB | NVIDIA GeForce GTX 960
Solved! Go to Solution.
2022-03-07 10:15 AM
When you say 3D object you mean element - column perhaps?
Objects are scripting and the problem you show could be down to bad scripting.
But it seems to have a reference line which is why I am thinking it is a column and not an object.
This can happen if you are modelling a long way from the Project Origin.
Always try to model close to the Project Origin.
2022-03-07 09:30 AM
@Johnsly Looks like the hotspots in 3D are independent of the shape’s geometry and the shape has been redefined? No short answer to fix that.
2022-03-07 10:15 AM
2022-03-07 11:57 AM - edited 2022-03-07 02:11 PM
As Barry said, this could also be a far from origin problem. See here:
Far From Origin - Troubleshooting Guide - Graphisoft Community
| Archicad 4.55 - 27
2022-03-07 12:47 PM
@Barry Kelly Well spotted. Definitely looks like a column.
