2006-04-08
04:11 AM
- last edited on
2023-05-23
03:30 PM
by
Rubia Torres
2006-04-08 05:22 AM
2006-04-08 06:06 PM
2006-04-10 08:31 PM
None of AC's tool elements are filletable.
2006-04-10 09:29 PM
Jesse wrote:ArchiCAD is a building modeler which is ultimately a far more complex specification than a 3D modeler. This means that more complex 3D forms have not yet been accommodated into the system (since it must also know what they are and at least something about what they are made of and how to build them).
So much for "solids modeling"
I guess I'll just have to fix all my sections and elevations by hand. 😛
At this point I think I'd be better off with a solids modeler and 2D drafting program. Unfortunately i don't get to pick the software at my office.
2006-04-10 09:39 PM
Jesse wrote:Do you have a sketch of this? I have a couple ideas bouncing around in my head that might get you the result you want, but I want to make sure I'm picturing the right thing.
Here in Hawaii a common detail is to have a roof with a moderate pitch that transitions to a low pitch along the perimeter with gentle radiused transition.
I am trying to figure out how to show this radiused transition.
I cannot find a tool to fillet these planes. In fact, I cannot see a way to fillet 3d objects at all. Were I to resort to the profiler, then I would wind up with additional false lines, no? Not to mention the fact that profiler objects are inflexible.
Mahalo!
2006-04-11 05:08 AM
Jesse wrote:Jesse,
Mahalo!
2006-04-11 06:01 PM
2006-04-12 05:27 AM
TomWaltz wrote:This is so simple it doesn't require a sketch. Imagine a 4:12 lower overhang. Above is a 6:12 hip roof. Where the pitch changes, I need to fillet with a radius of 10-20 feet.
Djordje wrote:That would not be the case for a hidden line drawing, and for elevations, there is no hatch.
Just create a Profiler object and fit it to the roof. If you use the roof surface fill, it is a good bet that the joint will not be seen at all.
2006-04-13 06:17 PM
Jesse wrote:Well, if the pitch is changing, as it is, there should be a line there!Djordje wrote:That would not be the case for a hidden line drawing, and for elevations, there is no hatch.
Jesse wrote:It is excellent that you are stubborn and a waste of software that the others can't see the forest from the trees ... funny ... did you have any training as the office with Rex?
No one else in my office uses the 3D portions of ArchiCAD, because even the best and the brightest cannot figure out how to get it to work the way the want. I guess I'm too stubborn. I hate to let a computer win any fight. I want sections and elevations to work, but usually what I wind up with is hideous compared to a strictly 2D drawing. So in the end I just wind up using the auto sections/elevations as an outline. :-~
