4 weeks ago
Hi all, I am having trouble getting a staggered intersection between 4 walls to work cleanly. My current result is:
Reference lines are as follows:
In Revit I would have just hidden the rogue line but if I can't get this to work then I guess the only option is a 2D patch fill (which i's rather avoid if I can). Any help would be most appreciated, Thanks
4 weeks ago
You could solve that intersection with a piece of wall the full width of the intersection.
I hope this helps.
4 weeks ago
Putting the reference lines on the "outside" of the intersection often works in such situations.
Hope that helps,
Bernd
4 weeks ago - last edited 4 weeks ago
Or you can mirror the reference line for this wall.
*And then stretch it to the nearest edge.
3 weeks ago - last edited 3 weeks ago
Another method is to model the central Wall geometry using the "Polygonal" Geometry Method and let all the other Walls join that geometry.
(This works only for non-composite walls.)
3 weeks ago
Or you can use a column for the classic workaround from 2010.
https://onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
3 weeks ago
Amazing, thanks everyone!
