‎2006-03-21
10:20 PM
‎2023-05-23
03:30 PM
Rubia Torres
‎2006-03-21 10:24 PM
‎2006-03-21 10:31 PM
‎2006-03-21 10:40 PM
‎2006-03-22 04:08 AM
Zobi wrote:Trim to roof.
The windows were FINE until I SEO'd the wall they are in with the roof. Then, they instantly got goppered up. Thoughts? Suggestions? Thank you!
‎2006-03-22 04:11 AM
‎2006-03-22 04:13 AM
Zobi wrote:... and have all kind of weird stuff happening, that you will spend more time troubleshooting than you need for re-trimming.
Yes, that does it, but w/ SEOing, I can move the roofs around and don't have to retrim...
‎2006-03-22 01:58 PM
‎2006-03-22 06:32 PM
‎2006-03-22 11:41 PM
TomWaltz wrote:A Workaround could be to place a "beam" as Trim piece on top and the bottom of the Window. This "beam" can be on a "3D Elevation" or 3D Bits layer that only displays in this view. ( Be aware of the intersection properties of this Layer as it relates to other views).
This is definitely a bug, but I am not aware of a workaround.
