A small GDL <>Info Box Trick
in many gdl objects other parameters can be controlled via Info Box
For example an object with a dimension not associated with A,B parameters size can use the Info Box a,b,size to other purposes by associating other parameters values for different values of A or B
IF A=1 then rotx 90... or mulx = -1..etc
IF A=2 then rotx 180... or mulx = 1..etc
if B= 0 then...
Endif
for example a wall label object can be mirrored by changing the
value of A parameter in Info Box Window
A=0,5 become A=1 and label is mirrored without open the object propriety window.> directly from the more accessible
Info Box
0 Replies 0
