2007-11-09 04:00 AM
2008-03-17 11:20 PM
2008-03-18 12:39 PM
2008-03-18 12:41 PM
2008-03-18 02:20 PM
Rakela wrote:The Library can only affect the marker itself. It doesn't affect how the tool itself works, which is what the wall problem is.
I thought this was fixd with the recent library hotfix
2008-03-18 09:51 PM
2008-03-24 05:34 PM
~/archiben wrote:That is a great site, top to bottom, thanks for sharing.
everything-you-always-wanted-to-know-about-interior-elevations. courtesy of james murray . . .
http://www.onland.info/archives/2008/03/interior_elevation_tool.php
~/archiben
2008-03-24 05:36 PM
2008-06-05 02:51 AM
Paul wrote:I found the only thing that works for me is I move the marker I want to delete out of view then I delete it from the project map.Laura wrote:For me even with only one marker selected, changing layer via Edit selection set changes layer on all markers in IE group. Only other workaround seems to be shifting the unwanted marker out to one side beyond extent of plan view saved to layout.Laura wrote:For anyone encountering the same problem: The layer setting cannot be changed (and stick) in the IE Marker dialog, but can be changed via the "Edit Selection Set" dialog.
Also, I've had reports of not being able to change the layer of an IE Marker once it is placed.
