AC 22 - SLOWDOWN #01 - SEARCH RESULT ON FAVORITES PALETTES CAME UP PAINFULLY SLOW
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-01-25 07:19 AM
In AC 22, whenever i try to use the search button on favorites, it will show the search result very very slowly.
It occurs whether you open the favorites from the icon on toolbox, or using a standalone favorites palette.
any clue on how to fix this would be greatly appreciated, thanks in advance
-John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-07 03:08 PM
I tried both version with around 1200 favorites, and I couldn't see a difference in speed. Could you try the same project in both versions and jot down how long it took in both versions to show the results of the same search?
In my test for example, I searched for "wall" in both versions, and (after multiple tests) in both versions I could choose from the results after 2 seconds, and it took about 10 seconds to load the preview images of all the results.
In general, if you set the Favorites palette to show '2D previews' and to 'Filter to Active Tool Only' in 'List View', you should get results faster.
Regards,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-27 05:37 PM
Acton Design Services
Windows 10 PRO 64 bit
i7-5820K @ 3.30ghz 32GB Ram
Nvidia GeForce GTX 1650 4GB Ram
AC 19 - AC 28
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-27 08:16 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-04-03 05:06 AM
dkovacs wrote:Hi, thanks for your reply and sorry for my very very late response.
I tried both version with around 1200 favorites, and I couldn't see a difference in speed. Could you try the same project in both versions and jot down how long it took in both versions to show the results of the same search?...
I've changed the favorites display settings to '2D previews' and 'Filter to Active Tool Only' but it didn't help.
It had the same problem whether i opened it with an active tool or not.
i was guessing maybe it had something to do with the 'folder' structure of the favorites, so i tried to move everything into a single folder but it didn't help.
If i may ask, how did you set the 1200 or so favorites in that test file? Did it also spread across all the tools available in archicad? Were the names of your favorites have some 'prefixes'?
Is it possible prefixes slowdown the search result in AC22? for example if i named my favorites:
Wall - external
Wall - external type 02
and so on, the same goes for other elements.
I haven't tested this one yet because it'll take to much time to try and rename thousands of favorites
toofuerte wrote:Yes, exactly, also, deleting the favorites seems to have little to no effect unless you delete almost all of the favorites, so number of favorites stored seems to be a bit irrelevant here
I have recently had the same thing happen, however I don't have more then 300 favorites and I am getting the same issue in the searching in the object settings box, once I start typing it take 30 + seconds before they show anything. When I am searching I try to put in several letters but it starts on the first letter and take 30-120+ seconds to then search with the two letters, and then does the same for the third letter, so the search can take several minutes. I am also having a long wait after changing tools. They may all be related
-John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-04-08 03:17 PM
A similar issue (probably the same) is being discussed in this Topic. You can join the conversation over there:
Regards,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-04-09 03:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-11 06:41 AM
Clicking a tool first is no solution because sometimes a roof functions as a slab.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-14 11:13 PM
Is it possible that Previews are not yet generated for all Favorites in the Favorites Palette? And once these Previews are generated, Search results will appear faster?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-08 06:45 PM
AC 19 - AC 28
