‎2019-01-25 07:19 AM
‎2019-02-07 03:08 PM
‎2019-02-27 05:37 PM
‎2019-03-27 08:16 AM
‎2019-04-03 05:06 AM
dkovacs wrote:Hi, thanks for your reply and sorry for my very very late response.
I tried both version with around 1200 favorites, and I couldn't see a difference in speed. Could you try the same project in both versions and jot down how long it took in both versions to show the results of the same search?...
In general, if you set the Favorites palette to show '2D previews' and to 'Filter to Active Tool Only' in 'List View', you should get results faster.
toofuerte wrote:Yes, exactly, also, deleting the favorites seems to have little to no effect unless you delete almost all of the favorites, so number of favorites stored seems to be a bit irrelevant here
I have recently had the same thing happen, however I don't have more then 300 favorites and I am getting the same issue in the searching in the object settings box, once I start typing it take 30 + seconds before they show anything. When I am searching I try to put in several letters but it starts on the first letter and take 30-120+ seconds to then search with the two letters, and then does the same for the third letter, so the search can take several minutes. I am also having a long wait after changing tools. They may all be related
‎2019-04-08 03:17 PM
‎2019-04-09 03:31 AM
‎2020-04-11 06:41 AM
‎2020-04-14 11:13 PM
‎2020-05-08 06:45 PM
