‎2009-09-15 08:17 PM
‎2009-09-15 08:21 PM
Henry wrote:INT > Metric library and enviroment profile.
Short question: what is the difference between Archicad International and Archicad USA?
Thanks
‎2009-09-15 08:25 PM
‎2009-09-15 08:55 PM
‎2009-09-16 02:01 PM
Piotr wrote:The INT version will work (well i know the AUS and INT versions both work on a AUS license).
Furthermore the INT version will probably work with the USA key, but check the legal issues when using US version of AC outside US, read carefully the license.
‎2009-09-16 02:29 PM
‎2009-09-16 05:13 PM
‎2009-09-16 05:19 PM
TomWaltz wrote:and i seem to remember you cannot actually create a 'Storey 0' .. so you have -1 & 1. Not sure if this would cause any problems with multi-storey elements if people are collaborating using different international versions (a particularly realistic possibility now with AC13).
- The INT numbers its ground floor 0 while the US version numbers it 1.
