‎2007-07-17
09:37 AM
‎2023-05-25
06:13 PM
Rubia Torres
‎2007-07-17 02:32 PM
‎2007-07-17 03:37 PM
‎2007-07-17 06:35 PM
‎2007-07-17 07:11 PM
Jay wrote:Is Gamma Testing the testing that is done just before the user gets ticked off and turns into The Hulk?
Thanks for all the continued, "beta" or Gamma Testing of AC11. I am on AC10 Still.
Will I be able to Upgrade to AC11 'Final' once AC12 comes out for It's Gamma Testing?
‎2007-07-17 09:39 PM
‎2007-07-24 03:16 PM
Richard wrote:The problem with debugging this error is that it can not be repeated on-demand, and we could never repeat this in an ArchiCAD debugger environment, which is necessary for the developer to be able to fix it. Now a bunch of QC guys are assigned to finding the exact steps to reproduce this - but if any of you have the "recipe", please share. We can repeat it time to time, but we don't yet see the pattern. But let me assure you - this bug is high priority on our list.
Yes, this this incredibly annoying and the latest update has NOT fixed it. What's maddening is that the problem was identified in beta, and STILL has not been fixed. I have to restart every 30-60 min., or so. It's at the top of my list for urgent fixes.
‎2007-07-25 11:47 AM
‎2007-07-25 04:25 PM
‎2007-07-25 04:53 PM
gkmethy wrote:After reading this reply, I find myself in awe of the debugging process. While a bunch of users are having meltdowns over an infuriating and time-consuming application behavior, some guy in a basement in Hungary is doing a time and motion study on the result of different keystrokes.
We finally have some luck with repeating this error. A 100% sure way to repeat it is to edit an element's parameters (e.g. height of a column) when in 3D - you change the parameter in the element's setting dialog, then close the dialog with hitting ENTER (Not by hitting the OK button). After this, the object previews are gone. It seems that if you close the dialog with the OK button, then the problem won't happen. This seems to be the way to avoid the problem.
