Eduardo Rolon
AC11 Detail Break Line
Has the Break Line for details been removed in the upgrade? If not where is it?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
24 Replies 24
Works fine for me. The "Built-In Detail Marker" seems to work the best.
Richard
AC26 (since AC6.0), Win10
Eduardo Rolon
That's the one I am using. I only have 3 hotspots and if the marker line is not in a corner then it is either horizontal or vertical and there are no options to specify the break line point in the marker settings.
AC29 US/INT -> AC08
Yeah, I see what you mean now. The "Detail Indicator_NCS" will get you there, although you may have to play around with the pet palette a bit to stretch or drag appropriately.
Richard
Eduardo Rolon
Actually none of the markers work for what I need, except if I keep drawing using either AC10, 09 and 08.
Can not import the marker from AC 10 because the Auto reference does not work. This is what I hate about upgrade-downgrades. One item that I have used without problem now is broken because somebody decided that Detail Markers do not need the break line and now I have to change my 20 years drawing convention to what a programer decided is the way I should draw.
I appreciate that the marker now does not separate from the bubble but at the expense of taking away the break line?
The firsts days with an upgrade are a pain.
AC29 US/INT -> AC08
Eduardo Rolon
Got IT! Does not work as previous ones but is as close as I am going to get.
AC29 US/INT -> AC08
You can get it to be identical to what you want. Try copying the Detail Indicator_NCS from your AC9 Library to your AC11 Library, and using that.
Richard
Eduardo Rolon
thanks Richard
Importing/copying the one from AC09 does not work since the Auto Text is looking for Plotmaker.
AC29 US/INT -> AC08
Oh, you wanted the new detail linking, too? Boy, you're demanding.
Richard
Eduardo Rolon
I thought I read somewhere that AC11 was a paid upgrade and I was under the misconception that certain tools were improved
Maybe it was just the yearly donation to the Church of BIM and not a feature list what I read about…
AC29 US/INT -> AC08
