‎2009-02-19 07:44 PM
‎2009-02-19 07:59 PM
‎2009-02-19 08:24 PM
‎2009-02-19 08:26 PM
Chazz wrote:It's the answer I resort to when stumped by bizarre behavior...
Sheesh Laura, right off the bat you're questioning the legitimacy of his license.....
‎2009-02-19 08:49 PM
‎2009-02-19 08:58 PM
‎2009-02-19 11:06 PM
‎2009-02-19 11:39 PM
‎2009-02-20 04:09 AM
Does the whole Navigator reappear intact when you reset the Work Environment to the Standard Profile?No, but resetting the Work Environment to the Standard Profile is what I do to get the Navigator to reappear. The View Map and Layout Map are still corrupted, but at least I can close the file. Assuming I don't save the file at this point (which seems to lock in the corrupted Navigator), I can then reopen the file normally, and the Navigator Maps are intact again.
‎2009-02-20 06:30 AM
Chazz wrote:Chazz, this means you'll be picking up the tab when you buy Craig lunch
It's either that or we need to start bringing Craig's manhood into question....
