AC12 - Special Menu
Hi, All
How I can open and show special menu in my AC12?
I'm open and edit registry for Special Menu (0) to (1) in AC12 Registry
Why not show in menu AC12?
Please help me for any solution
Thanks
undefined
21 REPLIES 21
Link
You still need to create a menu for it. Try a search.
Link.
Thanks LINK
Open Special Menu AC12 (0) to (1) in Regedit Windows
Run AC12, Create Special Menu and Drag to new menu (Special Menu)
Special menu hide in all command by theme with status (0) in AC12
Rod Jurich
Eddy, you need to open your WE and add Special to your menu structure.
Remember to redefine/create in order to save as your default.
Rod Jurich
Thanks Rod
I Succesly Special Menu AC12
Pict Attach
Dennis Lee
What is this special menu good for? Is this recommended for all users?
I started in AC10, so don't really know what this is for.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
The special menu serves mainly as a parking space for developer functions and potential, partly implemented, features. It is not supported by GS and is not recommended for general use. It usually has some tools that are handy for managers, library part developers and some advanced users.
The only time I recall setting it up for standard use was when I was working with James Murray way back when it was the only way to get the 3D hatch in elevations. For people making GDL libraries it has the handy function of placing all the parts of currently loaded libraries (and there are some quirks and tricks to this).
The bottom line is if you don't know why you need it you probably don't.
Dennis Lee
Thanks Matthew!
Windows 10 x64
Since ArchiCAD 9
Maybe it's no longer in the US 12??
Did you enable the Special menu in the Registry Editor, just as it is mentioned at the front end of the thread?
