AC12 - color of active selected items - can I change it?
When I click on a line, or whatever in the 2D working window, the line when selected turns an opaque color of it's original color.
In AC10, every item I selected turns green, or red, or whatever color I set it at. Where do I, or can I set this up in AC12?? I have been looking everywhere and can't for the life of me find this setting, which I know HAS to be there somewhere - hopefully.
In AC10, I changed this in the Work Environment - Selection and Element Information by changing the Contour Color.
Could it be I need to change to a new User Preference Scheme??
TIA
7 REPLIES 7
Work Environment > Selection and Element Information.
Which is what I've been trying, but it doesn't work the same for me in ArchiCad 12. It will change the hue of the color when I select a line, each line type will be a different color when I select several - i.e. circles, arcs, line, polylines, splines, they all will turn a different subdued or opaque hue of their original color.
I have no clue what the heck is going on. I go back to AC10 and it works just like it should.
For example, this pic is an AC10 project. All items selected turn red, as they should. If I open this project in AC12, it will function the same way.
A different project, an AC12 original project, the lines selected all turn different colors, based somehow on their original colors, as cyan always turns grey, yellow turns orange, blue turns purple, etc. There are two rows of lines here, same colors top row and bottom row. As you can see the bottom row are selected, but do not turn red, but each a different color.
As you can see I have the Selection and Element Information set exactly the same in AC10 and AC12, but the lines do not all turn red in AC12 like they do in AC10.
Oddly, if I open the AC10 project with AC12, it functions properly as it did opened in AC10. That must mean I have some preference that is set to some AC12 standard that the AC10 project doesn't adhere to.
There has to be a scheme or a standard or something that isn't set right that I'm missing somewhere, but it's driving me crazy!!!
Seems odd.
But it is true.
I never really noticed as I usually work with hairlines.
But turn true line weight on and it shows up more.
Version 13 is the same.
Interestingly when you turn off the "Highlight selected element's contours" checkbox and then turn it back on again it shows a transparent fill - not solid.
I would report this to your Archicad distributor.
I will do the same here.
What happens if you uncheck the "Highlight selected elements' surfaces"?
Maybe if line are displayed with True Lineweight then it think it is a surface so puts the additional green selection color to it as well and this causes the color change.
Could this have something to do with having 'Automatic Pen Color Visibility Adjustment for Model Views' turned on? Look in the 'More Options' section of the work environment and try turning it on or off and see if it makes any difference.
I thought it might be that too but unfortunately not.
No, I never have this on anyway.
I tried turning it on and no difference.
Are others having this issue as well?
I don't see it as a big problem as I don't use a lot of line work and I still can see what is selected especially in hairline mode.
But it has got my curiosity now and I can't see why it should have changed since version 10.
