AC15 Composite Skin Trimming
Having an issue with wall intersections where one wall "Tees" into another. This is a composite that was used in AC14 and I had no problems with it. I've tried everything I know in AC 15, skin priorities and, layer priorities, even checked model view options?? Also set renovation status of all walls to new & show with no overrides. I'm sure it's basic but I've spent a couple hours searching and fiddling already....
3 Replies 3
I'm guessing that your reference lines are not touching? - required for clean-up.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Unfortunately they are...
Did you enable skin priorities of that walls?
See the picture to know what did I mean.
