AC21 Railings....hubboy...
rob2218
so, we have no video tutorials of exactly how to do the AC21 railings. fine...so then how/where are the railings that I can associate to the stairs that have the "wire rails"? How can I adjust the railings to contains those "wire rails"?
(see attached image) I need the railings on the stairs which are currently associated to look like the "wire rail" on the left.....how can I accomplish this?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
40 REPLIES 40
No image attached.
What choices do you have in your railing favourites?
The default template should have something which you can export then import into any job.
Might not be exactly what you want but you can adjust all the settings.
If/when you create a stair or railing you will use again I highly recommend saving it as a favourite or saving it in a 'sample' file that you can copy into any other job.
Setting up these stairs and railings is going to be a long and tedious task.
Something you won't want to do again and again if you can avoid it.
I just had a quick look at the wire railing (image attached) and it all looks good until you need to adjust the height.
Then you must adjust (add/remove) the height of all the individual wire rails.
I am hoping there is an easier way - a custom panel maybe?
No that wouldn't work as the height of each wire would stretch along with the spacing?
Rob,
Why not just spend an evening exploring the new tools and the way they operate rather than just looking for an immediate answer. If you can understand how the tool works you will be able to master it sooner and find out alternative uses for the tool(s)
Scott
rob2218
Barry:
How did you access that "wired railing" object as it relates to adding a railing to the stairs?
Please explain.
Scott:
I plan on spending a few nights understanding this new tool but as you are very well aware...it's always the same. Client pressures dictate that we KNOW and UNDERSTAND how to use the software before it is created. You know that Scott...come on.
So, yesterday I was futsing wiht that "sketch panel" thats inside the railing settings and I see how to add (+) using the + or - tabs on the upper right but how do you adjust the railings pattern width? Can't see to touch/grab/select the vertical dashed lines to make the panel width what I want.
Also....when you place (+) add another "rail" component...how do you set it "EXACTLY" a specified distance where you want it?
Also, the rail components have this "gap" above them that I can't seem to remove.......too many questions guys, we need a a comprehensive video that explains in details how to operate the new railing tool. it's a bit complex. Sure I know, I'm well aware of that once you are shown how to do it.....its simple.........but please we need help GS. We need good tutorials. Not that "stereo manual" instructions that we've been reading for years now. It seems that GS has the same dude for the last 30 years writing the "instructions" portion on their site without realizing that we can't really understand the instruction for new tools. it's not written comprehensively nor is it an easy step-by-step how to follow format...it's very choppy to say the least. Good instructions GS, please.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Barry:
When I select the "railing" tool, I don't get that "folder drop out sideways" that you see in your image that shows you being able to select railing from a "folder" I get only the "favorites" button pop out which I can't seem to figure out just how to access the AC21 railing types? See....that's what I'm talkin' bout.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
So...from these (ahem) instructions...
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/elements-of-the-vir...
I see that a pullout menu can be accessed, though on my pull out menu for the "railings tool" I can't seem to access anything other than "Favorites"? What button/toggle/pull-out triangle can I click on to go to the library of parts for the "railings"? I'm sure there are some stock OTB standard wired rails but I can't seem to find the folder where to access them from? Help GS.
i>u
Edgewater, FL!
SOFTWARE VERSION:
DGSketcher
Legend
For anyone else struggling with the new tools and reaching for the internet it is worth remembering that within AC under the drop down Help menu you will have ARCHICAD 21 Help.pdf, the AC user manual, which can be read at leisure offline.
rob2218
are you kidding me? Read the "help" menu? it's worse than reading it online. it's like reading a stereo manual for Petes Sake.......we need "step-by-step" instructional videos ASAP from GS guys. This hunting and pecking and fumbling thru the tool just to get a railing inserted is nonsense....seriously.
it's a chore to have to go thru these kinds of BIM gymnastics to try and use the tool effectively and efficiently. Lots of wasted time while all the while the client is breathing down yer neck asking you "when am I going to get that stair done"?
i>u
Edgewater, FL!
SOFTWARE VERSION:
This is why I think there will never be a Stair Tool that can be more useful for the results I am after in terms of the model, details, and the material lists, than simply modeling the stair with individual parts from other stairs, or simply modifying a similar stair to fit the new conditions.
Stair Tool?
rob2218
Steve....agreed.
Everytime GS makes some new "tool"...man, it's hell to figure out. Again, we just want to use a tool that can accommodate "most" (notice I said most not all) of the normal stair parameters.......just a usable tool that isn't so complex to work with.
Either that or please GS....give us some videos that show us a step-by-step on how to use these new tools...
i>u
Edgewater, FL!
SOFTWARE VERSION:
