‎2022-12-09 08:19 AM
AC26
Windows 10
I have customized a fill, but it will not show on the material i have assigned it. It will only follow the screen only pattern.
Solved! Go to Solution.
‎2022-12-09 10:22 AM
It isn't your fill that is the problem, it is your On Screen settings. See this section of the online help for Fill Display Mode: True Fill Appearance vs. Bitmap.
‎2022-12-09 10:37 AM
I See. Got it. thank you so much. RESOLVED
