jkershaw
AC27 USA Tracker calcs with Imperial Units
Among the new features of AC27 is the option to multiply or divide values in the Tracker. I've been experimenting with this function, and I'm not convinced it is working as designed.
Default input in the USA is FEET. In other words, if one does not specify FEET or INCHES, AC assumes the input is in FEET. So... inputing "5" into the tracker results in a movement of 5'. Well and good.
However, when inputting "5/2" into the tracker, the element moves 2-1/2".
Equally baffling, when inputting "5'/2" into the tracker, the element moves 5'. Likewise, inputting "5"/2" results in a movement of 5".
It seems to me that the new tracker feature:
a. can only divide integers (cannot handle input of FEET or INCHES)
b. divides integers (default FEET) and outputs the result in INCHES.
What am I not understanding?
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
3 Replies 3
Eduardo Rolon
Tracker calculation for Imperial units are buggy in 27 but better than during the Beta.
"/" has been the shortcut for inches for 20+ years so typing 5/2 would presume 5" ÷ 2 if AC units are set to Feet with Fractional Inches.
5'/2 nor 5//2 don't work either.
This is another of the classic examples of GS implementing a feature that somebody wished was a good idea and failing in the execution. In this case forgetting that "/" was a shortcut
More bug info here:
https://community.graphisoft.com/t5/Installation-update/Archicad-27-Tracker-Input-glitch-using-forwa...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
jkershaw
@Eduardo Rolon wrote:
"/" has been the shortcut for inches for 20+ years...
huh. learn something new every day.
thanks for the response
13.2 macOS Ventura
NateLumen
This is a challenge for us as well. I would love to get this issue bumped since the math functions have so much potential. Just a little half baked for the Imperial folks.
Nate Lumen
Apple MacBook Pro M1
Archicad 27-29
