2005-09-08 07:48 PM
2005-09-08 08:06 PM
Jay wrote:The problems you describe sound like the same Archicad/Plotmaker linking problem we have all the time, teamworked or not.
If there is a team member working on the AC model and another member opens the PM layout book, when the second person tries to update a drawing, the results are always wrong -- missing lines, missing objects, elements moved.
If a team member is working in the PM layout book and another member opens the model in AC, the drawings in the PM layout book can no longer be updated. It says the AC model is locked.
2005-09-09 12:18 AM
2005-09-09 04:31 PM
s2art wrote:Ditto. If I have 50 different objects in my model, how am I supposed to find the one that is causing the problem? If it would tell me what it didn't like, it might actually be useful.
And I get the Library loading error message, which I have just learned to live with as it seems to have no effect whatsoever.
2005-09-28 03:43 PM
2005-09-28 05:24 PM
Tomasz wrote:This is a known problem. I assume the fix is not coming until AC10. For now our staff has been informed not to ignore the message that the file is already open unless you know that you have it open on your machine.
90% of the time I try to update the layout book while the .pln file is open on another client machine, I get crappy results
(No updates, just errors, and the first quickview link on the Drawing Usage list becomes a .pmk link filled with random cache content).
I have reported this problem to our AC dealer.
