AC9 - Can't drag a copy of a library part in section window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-10-15
02:24 PM
2023-05-26
03:20 PM
Rubia Torres
Mac OSX 10.3 G5 ArchiCAD 9.0
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-18 05:11 PM
Come on!
I thought perhaps I was just crazy since nooone responed to this aging query, but I just checked again, and the behaviour is the same. Working in a unlinked (now simply "Drawing" status, in 9.0), I can't drag-a-copy of a library part.
What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-18 05:53 PM
RobertNichols wrote:You could never do this. Windows, doors, all 2D elements, yes. Everything else, no.
What am I missing?
Try 3D window. With OpenGL on of course.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-19 12:47 PM
RobertNichols wrote:Do other objects drag in the section window? And I'm assuming that the library part is a 2D symbol as the section is unlinked. Is the file teamworked? I have seen this problem with AC8.1 and teamworked files on certain section windows. You would need to redefine your workspace (without really redefining anything) and it would go away.
No takers!!??!!
Come on!
What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-20 10:38 PM
I'm using 2d parts. I've tested my original pln file (which was Teamworked in v7, but now solo in v9), and in a new v9 document.
Same behavior with my own parts of native Graphisoft v9 parts.
I can successfully drag-a-copy of any 2d library part in a detail window, but in the section window, no.
Doesn't it seem odd, that drag-a-copy is disabled, but Multiply is allowed?????
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-21 03:06 PM
RobertNichols wrote:Consistency is hard to spell ...
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-21 03:34 PM
RobertNichols wrote:Just tried it, and it works - Drag, invoked from the context menu or shortcut, hit CTRL ot CTRL ALT, and you have Drag a copy or Drag a multiple copy.
Reading the last two repsonses, I started to wonder if I am crazy, but after retesting, I think not.
Or am I missing a point?
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-21 04:28 PM
When I look at my undo menu, though, it says Undo Drag Multiply/1.
At all times, the simple Drag-A-Copy menu item and keyboard shortcut are not available.
Perhaps its a Mac thing. Obviously, I can get the functionality I need: in section windows, to make a single copy of a library part the operation will always be a Drag Multiple of 1.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-25 06:44 PM
RobertNichols wrote:Likewise. As I weaned mself off the Drag a copy and prefer the ALT and CTRL (OPTION and ALT for you) method as I can switch between the modes, I don't find this behavior is a problem.
Thanks for testing, Djordje. I get similar results, but it still seems odd. Contextual menu, dragging after hitting cmd-key (Mac) produces a single copy.
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-26 11:52 PM
Anyway, there is no enable or disable of the element copy transformation commands, but it seems to be parallel to the issue. Hopefully, there is a workaround...
v2
