2004-10-15
02:24 PM
2023-05-26
03:20 PM
Rubia Torres
2004-10-18 05:11 PM
2004-10-18 05:53 PM
RobertNichols wrote:You could never do this. Windows, doors, all 2D elements, yes. Everything else, no.
I thought perhaps I was just crazy since nooone responed to this aging query, but I just checked again, and the behaviour is the same. Working in a unlinked (now simply "Drawing" status, in 9.0), I can't drag-a-copy of a library part.
What am I missing?
2004-10-19 12:47 PM
RobertNichols wrote:Do other objects drag in the section window? And I'm assuming that the library part is a 2D symbol as the section is unlinked. Is the file teamworked? I have seen this problem with AC8.1 and teamworked files on certain section windows. You would need to redefine your workspace (without really redefining anything) and it would go away.
No takers!!??!!
Come on!
What am I missing?
2004-10-20 10:38 PM
2004-10-21 03:06 PM
RobertNichols wrote:Consistency is hard to spell ...
Doesn't it seem odd, that drag-a-copy is disabled, but Multiply is allowed?????
2004-10-21 03:34 PM
RobertNichols wrote:Just tried it, and it works - Drag, invoked from the context menu or shortcut, hit CTRL ot CTRL ALT, and you have Drag a copy or Drag a multiple copy.
Reading the last two repsonses, I started to wonder if I am crazy, but after retesting, I think not.
I can successfully drag-a-copy of any 2d library part in a detail window, but in the section window, no.
2004-10-21 04:28 PM
2004-10-25 06:44 PM
RobertNichols wrote:Likewise. As I weaned mself off the Drag a copy and prefer the ALT and CTRL (OPTION and ALT for you) method as I can switch between the modes, I don't find this behavior is a problem.
Thanks for testing, Djordje. I get similar results, but it still seems odd. Contextual menu, dragging after hitting cmd-key (Mac) produces a single copy.
When I look at my undo menu, though, it says Undo Drag Multiply/1.
At all times, the simple Drag-A-Copy menu item and keyboard shortcut are not available.
2004-10-26 11:52 PM
