‎2015-05-14 02:38 PM
‎2015-06-12 04:01 AM
‎2015-06-15 03:10 PM
Steve wrote:Maxwell is a CPU renderer just like Cinerender, so your GPU will not make your renders go any faster (it does use the GPU for updating multilight, but the actual rendering is plain CPU).
I was referring to rendering with ArchiCAD.
My mobile workstation came with a general purpose video card and a
2GB nVIDIA Quadro 4000M for use with processing files that are compatible with GPU processing. I use it with Maxwell Render but ArchiCAD rendering is not taking advantage of it because ArchiCAD is not GPU compatible in that regard. ( as far as I know )
‎2015-06-19 03:41 PM
Matt wrote:KeesW wrote:It seems to be a common misconception with many ArchiCAD users that a high end graphics card will make a huge difference to the overall performance of ArchiCAD.
If one does good quality architectural work comprising the usual plans, elevations, sections and some 3D to illustrate proposals without making presentation one's life's work, is it worth paying the extra for high end graphic cards?
From all of the testing our company has done (and there has been a fair bit) the graphics card doesn't make a lot of difference. In my opinion, assuming you aren't doing regular rendering, you are better off saving some money on the graphics card and getting an SSD, followed by a better processor. RAM is also cheap so there's no reason not to have plenty.
We've also found that it's not always thetypeof graphics card you have but the exact driver version that can make quite a substantial difference. Some driver versions work with ArchiCAD a lot better than others.
‎2015-08-09 03:15 PM
johnadrian wrote:I have one of these machines and we have seen on our converted project to 19 an actual slowdown overall and have not seen any background processing improvements. The worst is the multi story marque, if it is active on plan viewpoint then switching windows brings up spinning beach ball for what seems likes minutes.
"Beta testers have told me that it’s a significant improvement and absolutely screams on Apple’s new Mac Pro, which comes with an Intel Xeon processor with up to 12 cores." ". . . ArchiCAD 19 is the only multi core BIM tool that could justify the purchase of a lovely Mac Pro and make use of the cores on its Xeon processor."Thank you for sharing the article it is a good read
‎2015-08-20 12:55 AM
Stan wrote:I agree with Stan. Straight out of the box Archicad 19 seems slower than 18 generating windows and updates. I've yet to experiment with it but it is a frustrating start.johnadrian wrote:I have one of these machines and we have seen on our converted project to 19 an actual slowdown overall and have not seen any background processing improvements. The worst is the multi story marque, if it is active on plan viewpoint then switching windows brings up spinning beach ball for what seems likes minutes.
Updates of drawings takes longer.
‎2015-09-01 10:03 PM
‎2015-09-02 02:20 AM
‎2015-09-10 11:16 AM
‎2015-09-10 03:31 PM
‎2015-09-10 03:46 PM
