ARCHICAD 19 - wall doesn't extend in sectional view
I have a problem with Archicad 19. I opened a file in Archicad 19 , which I made in Archicad 18. It turned out that I can't extend walls in section. I even have the same problem when I make a project only in Archicad 19. Does anyone know why it is that?
Eduardo Rolon
it is a bug, workaround is to select wall an another 2d element (line, text) and then you might be able to edit it. If not you will have to do it in floor plan or 3D Window.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
