ARCHICAD 20 Update 7001 Released
Csaba Kezer
Dear All,
Today we have made available the preview version of our next ARCHICAD, BIM Server and BIMcloud 20 Updates. We have tested the packages with the AUS, INT, UKI and USA versions so far and they all passed our Quality Control. The packages are compatible, but yet to be tested with the other language versions.
Depending on the feedback from this preview period, we plan to continue testing the packages for the rest of the language versions and releasing the update publicly in a few weeks time.
You can read the Release Notes and download the packages from here:
- ARCHICAD & BIM Server 20 Update 7001
- BIMcloud 20 Update 7000
Best regards,
Csaba
Csaba Kézér
VP, Global Customer Support
7 REPLIES 7
Ben Cohen
Hi Csaba
It seems the boundary lines issue has been fixed with this update. Which is great!!!
Is this correct? (Its not mentioned in the release notes)
http://archicad-talk.graphisoft.com/viewtopic.php?t=56608&postdays=0&postorder=desc&&start=10
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Csaba Kezer
Ben wrote:
Hi Csaba
Hi Ben,
Indeed, we have fixed it in Build 7000, we just forgot to include it in the list of improvements. Now you can find it in the list as well.
Csaba
Csaba Kézér
Csaba wrote:
Dear All,
Best regards,
Csaba
Sadly I keep getting spinning wheel every time I try to move or use some similar easy task on High Sierra.
Aaron Bourgoin
clean install, like this: https://bim6x.com/blog/speeding-your-performance-archicad-21
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
Thank you, but right after I installed the 7001 update it worked well, but after a couple of days it's the same as before..But of course I'll try it because it's unusable now..
Csaba Kezer
ARCHICAD 20 Update 7001 Officially Released!
We have released the Updates for all language versions through ARCHICAD's Check for Updates feature.
You can read the Release Notes and download the packages through the links in my first post.
Csaba
Csaba Kézér
Csaba Kezer
We have replaced the Windows version of ARCHICAD 20 Update 7001 with a newer, Build 7005 package to address a regression issue: https://helpcenter.graphisoft.com/?p=75862
The new package is available through ARCHICAD's Check for Updates function and on our Download site.
ARCHICAD 20 Update Build 7005 remains compatible with Build 7001.
Best regards,
Csaba Kézér
