ARCHICAD 21 RELEASED
The ARCHICAD 21 INT, GER and AUT versions are now available for download at:
http://www.graphisoft.com/downloads/
Other localized versions will be released in the coming weeks and months.
37 REPLIES 37
Aaron wrote:
USA version to be released June 19.
Aaron,
I am waiting. June 19th come and gone and no USA version yet. Where did you hear this? Or were you just wishful thinking.
Gerald
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Aaron Bourgoin
Gerald, that was a published date. Tapping my fingers on the desk about this. Our transition to 21 is important - mission critical, even. I'm not playing around with he INT version while I wait.
I've got 40 people to transition to BIM from version 18 by Labour Day. Every day until then is important.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
Jeff Griffin
AC21 USA is now available.
http://www.graphisoft.com/downloads/archicad/install/AC21/USA/
iMac 27 (2020) 3.8 GHz Core i7; 128 GB RAM; Radeon Pro 5700 XT 16 GB GPU (macOS Sequoia)
MacBook Pro M1 Max; 64 GB RAM; 10CPU/32GPU cores (macOS Sequoia)
ArchiCAD 29/28/27 USA Full (back when Full used to mean Full) (latest builds). User since AC12 (2008).
Jeff Kogut
Thanks for the link! Now, if you all would just pause your downloads so I can finish mine.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
stefan
Also for student versions? Because i can't download Archicad 21 student version.
As a student, you can use the same installer. But if you have a language-specific student license, you need to use the related installer. Unless you switch your language preference to the INT version in the MyARCHICAD portal.
FWIW, student licenses are not version-specific (AC20 license works for AC21) but are language specific (only INT license can activate INT installation).
Archicad-user since 1998
my Archicad Book
Chris Phillips
Is there an update on the UKI version release date?
PB
"The estimated release date of ARCHICAD V21 is on the 3rd of July..."
Latest update from our contact
Latest: 04/07/2017.........not released yet
AC29. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 26 Tahoe
DGSketcher
Legend
Todays advice from GSUK - "still being localised and it’s scheduled for imminent release."
Interpret "imminent" to your personal expectation. Hopefully it's a sign they are being thorough in squashing bugs rather than short staffed...
PB
I appreciate the work done to create a UKI specific work template with good integration of layers, layer combinations, and workflow through the organiser: It must be quite a task!
One thing has always bothered me: The very odd choice of default pen & fill selections in the tool settings. Presumably, there is a logic to it....but I've no idea what it is, and it certainly does not work for us...
Perhaps an additional pleasant surprise coming with this release....workable default pen & fill selections in the tool settings....
(I do remember a thread by one of the alumni of this AC forum discussing the need to thoroughly go through these settings at each release: I'll have to look it up and see if there is an efficient/logical way of doing it).
AC29. Twinmotion.
(I've moved posts related to the online purchase of the USA AC 21 upgrade to another topic: http://archicad-talk.graphisoft.com/viewtopic.php?t=56844
Please keep this topic focused on features / your thoughts on the new features and find or open a new topic for any in depth discussion of a particular issue.)
