ARCHICAD 21 Update 5010 Released
Csaba Kezer
Dear All,
Today we have started to release the next ARCHICAD 21 Update publicly. The Update is already available for the AUS, INT, UKI and USA languages through ARCHICAD’s Check For Updates feature. The update will be available for the rest of the language versions as soon as it passes our Quality Control.
The update is currently available for ARCHICAD only. The BIM Server and BIMcloud updates with the matching build number will be released later on, for now we will keep them in preview status until we get some additional user validation on their stability.
Starting with version 21 the build number tolerance between ARCHICAD and BIMcloud/BIM Server is much more allowing. As a result you can update the server separately from ARCHICADs and vice versa. Projects remain tied to a specific ARCHICAD version, so make sure that all ARCHICADs are updated together. Therefore ARCHICADs updated to build 5010 remain compatible with BIM Server/BIMcloud 21 Update 4003.
You can read the Release Notes and download the ARCHICAD 21 Update 5010 from here:
http://www.graphisoft.com/downloads/archicad/updates/AC21/AC21-4022to5010-ReleaseNotes.html
Best regards,
Csaba Kézér
Director, Global Customer Support
11 REPLIES 11
mi_jan wrote:
laszlonagy wrote:
Until then you might want to uninstall build 5010 on that machine, then reinstall AC21 and upgrade it to the build used by the other computers.
We have some files that were created in build 5010, has anyone experienced any problems when reverting the file to 4022?
In the IMPORTANT NOTE, it says downgrading to 4022 may cause problems.
I tried reverting a file and I can't really find anything that messed up.
We had to revert our teamwork files back to 4022. No issues or lost info yet.
Csaba Kezer
Hi All,
ARCHICAD 21 Update 5021 is now released: https://archicad-talk.graphisoft.com/viewtopic.php?f=10&t=59277#p277374
Csaba Kézér
