2017-05-02 03:52 PM
2017-06-01 08:11 AM
2017-06-01 12:50 PM
Bricklyne wrote:This is "actually" kind of possible right now with the railing tool since you can add almost anything as a post, rail etc. and it will be associative with either a wall, slab, roof or mesh. One current example is adding trees to a site that follow the contours. Also you can control how it will look, either schematic or fully detailed.
Wouldn't be great to have some of this element "associativity" that the new stair and railing tool take advantage of, expand to other ArchiCAD tools and GDL objects?
I hope that's in the plans for the future.
Imagine having slabs (or roofs) that are able to host light objects as well as A/C vent outlets and MEP connections in much the same way that walls host windows and can move or update with the changes in the structure or position and also display correctly whether on floor plan or RCP. Or even a drain object for slabs that not only gets hosted by the slab but correctly displays the slope on the slab and adjusts to the slab shape changes.
Ditto walls themselves also being able to host more than just windows and doors, but also lights, MEP (tubs and toilets), vents outlets.
It's all very exciting.
another Moderator
2017-06-01 07:20 PM
stefan wrote:Right. Cagri asked about INT though.
Depends on your required localisation -- our regional version is announced for September
2017-06-02 11:55 PM
2017-06-03 07:21 PM
Bricklyne wrote:I am afraid that is not how it will work. If a Tread is converted into a Morph, that Tread will be "deleted" from the Stair, and you will have a separate Morph element in your Project at the location of that Tread.
What got me most excited from that presentation video was the ability to convert a component part of the stair tool into a morph, modify it's shape or geometry, and still have it read as a tread, for example, on the stair.
If I understood that sleek looking stair they modeled correctly, that is.
Same thing regarding how cool that would be for other complex ArchiCAD GDL elements allowing you to convert component parts into morphs and changing the geometry to custom shapes.
(like, imagine being able to convert a standard door handle part into a morph and adjust or changing the length, adding curvature,.....all on the fly and still have it read as a handle, rather than the conventional method of modeling it entirely as a separate object and saving it as a custom handle, which is fine, until you have to change one small thing on it).
2017-06-03 11:22 PM
Rogerdodge wrote:I am not aware of such a feature.
In cadimage stairs there is a very useful feature called the Head clearance plane, showing a translucent sheet parallel to the stairs showing the min. clearance.
Is there anything like this in AC21?
2017-06-04 06:05 AM
laszlonagy wrote:That's disappointing to hear.
If you want special shapes that are still part of the Stair, you will have to model them, then save them as Custom Stair Tread, then enter Stair Edit Mode, select the Treads you need to modify and change them to the Custom Tread from the Tread specified in the Settings Dialog.
2017-06-05 05:30 AM
Rogerdodge wrote:Roger,
2017-06-05 06:23 AM
2017-06-05 09:58 AM
datarchitect wrote:Thanks for that, not having it as part of the tool is only very minor in comparison the positives the new stair tool will offer, i can see that i will be using the AC stairs instead of the Cadimage stairs & adding a line or transparent fill or something is really not a big deal.
Roger,
See the below link for an article Jared wrote that does want I think you want.
https://blog.graphisoftus.com/archicad-education/tips-and-tricks/minimal-space-requirements-and-impr...
