ARCHICAD 22 INT version now available for download
It can now be downloaded from the following web page:
http://www.graphisoft.com/downloads/
Other localized versions will be coming soon.
23 REPLIES 23
James B
Also, the HelpCenter has been updated with tips and tricks, and details about the new features including those not mentioned in the videos yet.
https://helpcenter.graphisoft.com/
James Badcock
Your link doesn't work i still get the 21
On the lower right hand corner of that page, there is a localization setting for the website. Make sure that it is set to "International."
Richard
AC26 (since AC6.0), Win10
I found that you have to be signed in in the upper right corner for the downloads page to appear.
If you are not signed in, some other page will appear, not the downloads page.
David Pacifico
ArchiCAD 22 USA is now available for download
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
I've only been playing around with this for an hour or so, so I don't know what dragons are lurking within for this build. But so far, I like this release a LOT! Very snappy response, and nice screen display in 4K with display rescaling. It's a pleasure to work in.
Richard
insideru
INT version got bumped to b3006 as well. Should we reinstall?
ARCHICAD 28 INT
macOS Sequoia
If there is no automatic update option available for 3006, then, yes, I believe you should uninstall and reinstall the 3006 build as it fixes a bug involving wall trimming.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
James B
There should be an automatic updater, but may take a couple of days to roll out (I believe). This only affects the initial INT release.
3006 fixes the automatic dimensioning issue. The wall trim issue should be fixed in the next update.
But there should be a more offical word on it soon
James Badcock
