Daniel Kovacs
ARCHICAD 22 Update 6000 Preview Released
Dear All,
Today we have made the preview version of our third ARCHICAD 22 Update available. We have created and tested packages for the INT, AUS, NZE, UKI and USA language versions.
The Preview Update is only available for the above language versions. If you attempt to install it on a different language version, you will get an error message about this.
We will create Public Update packages for all language versions in the upcoming weeks. It will be possible to update from the Preview package to the Public one without a problem.
You can read the Release Notes and download the packages from here.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
19 Replies 19
KeesW
What is meant by 'Preview'? Does this term also apply to this release for named AC versions?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Daniel answered this question in the conversation about the previous Preview:
https://archicad-talk.graphisoft.com/viewtopic.php?f=10&p=290216#p290216
Were experiencing lots of unexpected crashing with 22:5009 SWE. Any date for 6000 SWE release?
It's getting a bit nervous here among our users.
DGSketcher
Legend
This doesn't work in AC22 6000 using profiled butt glazed frames. Gaps appear between the panels which can't be adjusted....
https://helpcenter.graphisoft.com/knowledgebase/84673/
DGSketcher
Legend
Rectangular Window Opening 22 shows a tapered head lining when using the variable closure. This may apply to all windows using this option. The result is also present in 3D and was also flagged up in an IFC export by the recipient.
I've you got an idea of the date of release ?
The beta is not available in French, and the 5000 version is the very very buggy
The search and find function alone makes at least 3 crash a day for Avery architects of our company !
Honestly, working 4 months with the 5000 version is the worst archicad experience I never had in a decade.
FYI : we work on mac.
agroni
dkovacs wrote:
Dear All,
is there any news about the new official 6000 release date in other languages?
The Dev team was probably busy with AC23, but now hopefuly could have the chance to develop this issue for ac22
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
Aaron Bourgoin
we're past 30 days from the preview release.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
DGSketcher
Legend
I have just come to add some dimensions to a project and noticed that selecting "Automatically dimension walls..." with "Core" or "Outer faces" will result in completion of the dimension process on the first click. This might be great for just dimensioning a single wall but I think the default should be to anticipate the creation of a chain of dimensions as previous. To create a chain of dimensions you now have to click on a node point first to stop the autocomplete process.
