2020-05-28 03:10 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-06-03 09:15 AM
2020-06-04 08:53 PM
mnguyen wrote:The same importing defect will happen with columns. That's sort of a request to fix the other tool also.
vdentello wrote:Hi,
ARCH-7876 FILE/IFC/IMPORT: If default beam end angle settings were modified, it affected IFC model elements imported as ARCHICAD beams.
I've been waiting for a solution close to this one.
Has it been done for columns? It will pick up actual column setting for Anchor Point when importing IFC complex profile Columns. That can be tricky. It's not listed nor obvious and can cause a huge mess. (Been through it)
Thank you for your question!
Although I don't really understand your wish, this issue is about a defect with ARCHICAD import function. Here is how it could be reproduced on previous AC23 builds:
1. Create a new file with the default template.
2. Set Beam Default setting with END CUTS 120, 120 (not 90, 90).
3. Merge the IFC file.
4. The imported Beams will have wrong end cuts.
Let me know if there is anything I can help!
Best regards,
Minh
2020-06-09 08:11 AM
Minh Nguyen
GRAPHISOFT
2020-06-25 02:54 PM
2020-06-30 02:37 PM
insideru wrote:Hi,
Is the view scale bug from interactive schedules fixed?
(Steps to reproduce: Set a windows/doors schedule. Place a view from O/R side or a 3d front view. Select the field, change scale to other than the default 1:100 <i changed it to 1:50> save the view and place on a layout. The scale changes back to 1:100)
Minh Nguyen
GRAPHISOFT
