Brett Brown
ARCHICAD functionality
Moderator comment:
This discussion was started in another thread, but then changed into the discussion of various ARCHICAD
functionalities, so the topic was split into its own discussion.
Christophe wrote:
Archicad is also the best and has always been!
Might have been 10 years ago but now it is far from it.
It is embarrassing the basic functions missing in Archicad that all the others have, Vectorworks, Revit, Archline XP, Cheif Architect.
The main downfall of Archicad is that it is the only Software that hasn't a central UI that you open all your projects in. This costs all users of Archicad hours a week in maintenance which the others don't have.
And as said all the basic usability functions which are to many to list which we all miss daily.
In the last few years all Graphisoft has been doing is updating (or making the tools more complicated to use) existing tools (Stairs,Curtain Wall, Beam, Column) which has been only beneficial to some, and this will be happening for a few more years to come. I bet there is a new Door and Window tool next.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
32 Replies 32
@Bricklyne Clarence
I think Brett Brown is talking about common/shared Attributes/Office_Standards between multiple projects. For example: You create a new GO/Detail/Property/etc to a common set of plans in one project, and have to replicate it manually to every other ones.
Hello Brett Brown,
I share the feeling of Bricklyne Clarence : the intentions of Brett Brown seem contrary to Archicad's working methods. No software can or should claim any functionality from other software. Therefore it is important at first to understand how to proceed with Archicad rather than wanting to find an exotic functionality. For more than 10 years I have never met Archicad users who need more than 3 files open at the same time. As for the attributes, they are all embedded in the TPL file which can be improved as you go.
I nevertheless think that graphisoft's progress in transferring attributes from files to files could be better: just like in Archicad 23 with its "home page" which allows you to synthesize the state of the file.
And maybe in a few weeks we will see that the subject is already solved with Archicad 24 !
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Braza wrote:
@Bricklyne Clarence
That's more or less what I understood him to be saying.
I think the confusion (for me) was from the conflation of saying "plans" when "projects" was what was actually meant, and essentially using them interchangeably.
"Plans" (as in Floor plans) are part of a Project, as far as I'm aware.
Although I get that once upon a time, the term "plans" was a catch-all term used to refer to any architectural document or drawing (even sections and elevations) and thus, also more generally refer to a project, overall.
Just like nowadays some people may (still) use "Blueprints" to mean anything Architecture drawing (or even CAD-) related, when, once againm, it's a very specific term that referred to a specific type of drawing (copy) of a hand-drafted drawing.
Christophe wrote:
Hello Brett Brown,
A "few weeks"???
Why are so many people so optimistic that we'll be seeing ArchiCAD 24 any time before the middle of the summer (which is when new releases typically get released) or even much later than that (given our most recent experience with a new release)?
And on that point, I'm not even sure how confident we really should be in a new version if it does in fact arrive on time this year, considering the fact that we're barely one Hotfix in (pre-release version) with the current version when we all know it normally takes a number of those before a version is actually considered stable enough and truly production-ready.
I hope you're right.
(.....but with lots of reservations, obviously.)
Brett Brown
Braza wrote:
@Bricklyne Clarence
Absolutely correct Braza, Sorry Bricklyne you misunderstood the problem. Vectorworks has the Resource Manager, Archline XP has the Design Centre, Revit to a certain extent, these are far more organized internally than Archicad will ever be. Or we can only wish Christophe for 24. My guess is 24 will be all about the new replacement Windows and Doors tool. Which will mean nothing to us that have used Cadimages one for years.
The overwelling feeling I have is Archicad has moved right away from supplying tools for the single-family residential home and the thinking that most of us have more than one project underway at the same time. You just have to look at the toolset of Revit and the way it works (OP question), for example, "pining" "Temporary dimensions" just to new a few of many many more. Autodesk has a totally different way of thinking where they know what we want. That's probably because they ask us what we want.
Christophe, "contrary to Archicads working methods" you mean antiquated working methods, and as you finally said, transferring attributes is painful and as it will never have a centralized "Resource Manager" we will have to hope an API maker will pick up the slack to improve Archicads usability. Now wheres the Keynote Manager? Oh, that's in Revit.
Common shared attributes will cause another issue.
What happens when you update an attribute but you don't want it in ALL of your projects?
Some you may want to share and others you may not.
We have that choice now with the Attribute Manager.
You may have 10 projects on the go at the same time, but adding a new layer combination or GO to one file, does not mean you have to add it to all of your files (unless you are hotlinking all the files together - then it is important to have the same attributes).
Update the project you are working on and transfer those attributes to your template so future projects are good.
If you really need it in other projects you can import the attributes there too.
But if it was important for all of your projects, then surely you would have had it in your template already?
I work for a project home builder and we have 100's if not 1000's of standard plans and 1000's of projects produced each year.
All are based from the same template which is kept up to date with any new attributes.
If we need them in existing projects we can import them in from the template.
We even save individual attribute files for a new layer combination or new complex profiles, etc., just so we can import those directly rather than searching for new attributes in the template or overwriting all attributes.
Erwin Edel
Maybe I'm too stuck in my ways, but there is very little changing with my template from version to version, just small things that get added. It helps that our local version 'keymember' edition ships with a fairly good template that follows the national standards and only needs small tweaks.
I do generally keep projects as they are. If there is too much hassle to upgrade them to the new version, we just finish them in the old version. I still have two projects running archicad20. AC20 is rock solid thouh, so I see no reason to worry there.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Then you "pack" things that are specific to a pln in a separate attribute file automatically linked to that pln.
The same with things that are common to all files (like office standards) in a single attribute file linked to the template file.
We know that this can be done manually. But every time I have to do this I feel I am walking on a mine field.
Things can get messy with index numbers between mod files.
Erwin Edel
We 'reserve' index numbers by having dummy attributes at hundred marks (200, 300, etc). We also use a naming protocol where we add our project number to the start of project specific attributes. This makes it easier to work with multiple files in one project.
Template: 1-200
Project shared: 201-300
Block A: 301-400
Block B: 401-500
etc etc
If something needs to change 'banks', then you can use 'delete and replace' to switch it from block to project and so on.
Changing template attributes is frowned upon. Always duplicate and give a new name starting with project number.
Sometimes we also add the design phase to the name if that will lead to many changes and again just slap them in a new index 'range'.
Good work discipline doesn't take much effort and saves a lot of time and headaches.
www.leloup.nl
Exactly! Making it easier doesn't mean it is perfect, right?
I know all these workarounds. But again: Its too much "discipline" for a task that should be automatic!
I don't want to do a "Japanese Tea Ceremony" just to add a new layer/linetype/property on a project that I may or may not share attributes in the future.
