2024-02-27 02:08 AM
I have recently upgraded to Archicad27 from an educational version. I am trying to add a single mesh point to an existing mesh (not a contour). I have the mesh selected, and the mesh tool highlighted. When I click space bar and double click, it is coming up with the "New Mesh Point Box", but when I click "ok" nothing happens. Has anyone got any tips on how to resolve this.
Thanks!
3 weeks ago
OK, I finally figured out why this wasn't working for us.
You need to be on the mesh's home story to add a point in plan view. If you are on a lower story, even if the mesh is visible, you are unable to add a point.
Our site mesh home story is the main floor, but our site plan view is from the story below that. I could see and select the site mesh because it was set to be visible on all stories below, but it wouldn't add a point unless I was in a main floor plan view.
3 weeks ago
I am glad you found the reason.
I would probably never have figured that out.
I don't use storeys for site plans, roof plans, etc.
I just use layers - no need to juggle what does or doesn't show on each storey.
And much easier for objects like stairs that pass from one storey to another without having to skip storeys.
