Ashleigh1
Adding a single point to mesh
I have recently upgraded to Archicad27 from an educational version.  I am trying to add a single mesh point to an existing mesh (not a contour).  I have the mesh selected, and the mesh tool highlighted.  When I click space bar and double click, it is coming up with the "New Mesh Point Box", but when I click "ok" nothing happens.  Has anyone got any tips on how to resolve this.
Thanks!
12 Replies 12
OK, I finally figured out why this wasn't working for us.
You need to be on the mesh's home story to add a point in plan view. If you are on a lower story, even if the mesh is visible, you are unable to add a point.
Our site mesh home story is the main floor, but our site plan view is from the story below that. I could see and select the site mesh because it was set to be visible on all stories below, but it wouldn't add a point unless I was in a main floor plan view.
Graphisoft Certified BIM Manager
AC27 USA - build 6000 - HP ZBook 15 G6 - Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM - Windows 10 Pro
I am glad you found the reason.
I would probably never have figured that out.
I don't use storeys for site plans, roof plans, etc.
I just use layers - no need to juggle what does or doesn't show on each storey.
And much easier for objects like stairs that pass from one storey to another without having to skip storeys.
I just discovered (?) that with a double click you create the point and the “fit to user ridges” dialog box pops up, and here one just needs to hit Enter twice to get to the point elevation settings (instead of okaying that dialog with a click/Enter, and then clicking on the point for setting its z).
