Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
All objects missing + windows and doors dimensions
anto_bg
Although I unhid all layers these elements are still missing and I have no idea how I can correct the issue. I am currently running AC25 in Win 10.
When I select a door or a window, the settings of the selected door show me that the dimension marker is set and it doesn't let me put a new one because there is already a marker there but it's not visible.
1 REPLY 1
Guru
Regarding the Door Marker, check your Model View Options (MVO).
Regarding your other objects, please share a screen clip of the issue. See link in my signature about adding images.
Ling.
