Angles between morph-surfaces
Hi!
I've been designing a coffeetable in archicad using the mesh-tool.
Since Im going to build this with plywood, I will need to know the angles between the parts. This seems hopeless in 2D, so is there anyway to find this in 3D? Tryed to mark of of the angles with red on the picture. Hope some of you brilliant minds have a solution to this.
Kamelite
roarner wrote:
Hi!
Built an eightsided roof once, much similar to what you want do to. You don't really need to know that angle. Make plane 1-6 according to your design. When putting them together, the angle you refers to comes automaticly!
.Kamelite
Windows 10, Archicad 27,28 and 29
Thank you for your respond.
I do hope there is a solution doing this without drawing the hole thing again
