ā2015-01-09 01:39 PM
ā2015-01-14 02:44 AM
Steve wrote:In your Work Environment > On-screen Options there is a setting to turn on/off 'auto hide snap points'.
perhaps it is my settings somewhere, but I am continually frustrated that snap points are not showing up when I need them. I don't like having to find a place on what I am wanting to see snap points on that will make them show up, and then racing to try and hit it before it disappears.
ā2015-01-14 04:04 AM
ā2015-01-14 04:11 AM
ā2015-01-14 04:43 PM
mcjh_matt wrote:I have the opposite problem!zeropointreference wrote:There is an easy way to avoid this, use the Drag keyboard shortcut (Ctrl+D) to initiate the drag command, you then don't have to worry about which pet palette option is active. This also means that if you do want to repeat a previous pet palette action it will be remembered after the drag rather than having to activate it again.
When I select a group of objects to move to another location, when I select a node it automatically selects a deform command instead of the drag command. 9999 times out of 10000 times I do this I'm looking to drag my group of objects. Once in a blue moon I might need to have multiple objects selected to see a deformation take place but it's almost never.
ā2015-01-14 10:25 PM
ā2015-01-14 10:48 PM
ā2015-01-16 08:51 PM
ā2015-01-16 08:56 PM
ā2015-01-16 09:51 PM
ā2015-01-16 10:03 PM
